Home » Audio » Speaker » vapor barrier
vapor barrier [message #19580] Fri, 31 October 2008 14:58 Go to next message
Carlos is currently offline  Carlos
When putting insulation inside speakers do you remove the vapor barrier paper first?
Re: vapor barrier [message #19581 is a reply to message #19580] Mon, 03 November 2008 12:43 Go to previous message
Dale is currently offline  Dale
Yes, remove the vapor barrier.
Previous Topic: Are cloth surround drivers boxy?
Next Topic: Goodbye Paradigms, looking for something new.... whats good?
Current Time: Sat Oct 17 16:37:36 CDT 2026
