Home » Audio » Speaker » BMS 2193 horn?
BMS 2193 horn? [message #19572] Thu, 02 October 2008 22:30 Go to next message
Has anyone used the BMS 2193 short horn?
Looking at its 1.4 kHz cutoff frequency. I would think a fairly high crossover point would be needed, possibly above 2.5 kHz.
Is there a reason to use these horns if one needs an x-over point below 2 kHz? They look like a good candidate for a bipolar speaker design with their shallow profile and dispersion angle mated to 8" direct radiator drivers.
Thanks
NW
Re: BMS 2193 horn? [message #19573 is a reply to message #19572] Fri, 03 October 2008 17:20 Go to previous message
Looks like a decent little horn. Maybe we should get one and measure it to see how well it works.
Previous Topic: crossover point
Next Topic: Design Stage : a 4-way system
Current Time: Sun Nov 08 19:53:37 CST 2026
