Home » Audio » Speaker » Ciare TW 1.8 horn tweeter from US Speaker?
Ciare TW 1.8 horn tweeter from US Speaker? [message #19103] Sun, 18 February 2007 13:53 Go to next message
ChrisL is currently offline  ChrisL
Anyone try one of these? Looks pretty beefy. Reasonablly priced, especially compared to a Beyma CP25 or the JBL types. I have NO commercial interest, just looking for a tweeter to add some air on top of an 811b.
Anyone?
Regards,
Chris L.
Re: Ciare TW 1.8 horn tweeter from US Speaker? [message #19104 is a reply to message #19103] Sun, 18 February 2007 23:49 Go to previous message
Hello Chris,
I have no experience with Ciare tweeters - I think they're fairly new to the US market. I do have experience with several of their woofers, and can say that the specs and frequency response curves have been very reliable (which unfortunately tends to be the exception rather than the rule).
Indeed they do look beefy! $55 for a 150 watts AES power handling 105 db efficient driver that's pretty smooth from 2.2k to 19k, except for a dip at 4 kHz which is not a bad place to have a dip.
Thanks for pointing it out to us! Now you've got my wheels a-turning...
Duke
Previous Topic: Newform R30 / Scan 8545 array
Next Topic: Two Inexpensive Near field Line Array Systems
Current Time: Fri Nov 13 21:35:55 CST 2026
