Home » Audio » Speaker » Mounting an 811 horn
Mounting an 811 horn [message #18758] Mon, 05 June 2006 16:39 Go to next message
Is it preferred to mount this horn to a baffle from the front of the baffle, or the back? The baffle is 3/4" thick. Thanks!
Re: Mounting an 811 horn [message #18759 is a reply to message #18758] Mon, 05 June 2006 18:08 Go to previous messageGo to next message
Although mounting from the rear is devine, "cowgirl" has it's good points, too.
Re: Mounting an 811 horn [message #18760 is a reply to message #18759] Mon, 05 June 2006 22:11 Go to previous messageGo to next message
Re: Mounting an 811 horn [message #18761 is a reply to message #18758] Mon, 05 June 2006 22:14 Go to previous messageGo to next message
If baffle mounting, it's best if you can make the mouth flush. A smooth transition is what you want with no abrupt changes. Also, baffle mounting makes the horn radiate into halfspace (as opposed to full-space) if the baffle is large enough. The 811 is large enough that it really doesn't need it if the crossover point is above 800Hz. But you can't ever be too smooth.
Re: Mounting an 811 horn [message #18763 is a reply to message #18760] Tue, 06 June 2006 11:12 Go to previous message
Yep, there's always a funny man around...
Previous Topic: Void Filling Foam?
Next Topic: Maxxhorn
Current Time: Sun Nov 08 11:57:06 CST 2026
