Home » Audio » Speaker » Any suggestions remarks on this design?
Any suggestions remarks on this design? [message #18692] Sun, 02 April 2006 17:01 Go to next message
Bas Horneman is currently offline  Bas Horneman
it's meant to go from 400Hz down. I'm a bit worried though after reading Sound Practices summer 92 and specifically Greg Boynton's remark that folded horns suck!
The driver will be a P.Audio BM12W.
Re: Any suggestions remarks on this design? [message #18693 is a reply to message #18692] Mon, 03 April 2006 10:42 Go to previous messageGo to next message
I think 400Hz is probably an octave too high because folding generally attenuates higher frequencies. Standing waves develop inside that tend to make lower midrange output ragged. So crossover lower than 400Hz but otherwise it's probably a pretty good layout. Have you modeled it in Hornresp?
Thanks again Wayne. I've relayed your feedback to the [message #18694 is a reply to message #18693] Mon, 03 April 2006 15:21 Go to previous message
designer.
Really appreciate your sharing of knowledge. The knowledge of hornloudspeakers is a lot scarcer than say about tubes.
Regards,
Bas
Previous Topic: DIY exponential/radial horns part
Next Topic: differential dual coils
Current Time: Tue Nov 03 04:09:56 CST 2026
