Home » Audio » Speaker » revisiting the Delta 12LF
revisiting the Delta 12LF [message #18342] Tue, 20 December 2005 15:32 Go to next message
Scholl is currently offline  Scholl
Hi all,
The corner horn thing might not make it past the wife so I'm thinking up other ideas for a compact system. The good old Delta 12LF in a closed box for 60hz crossed to a Parts Express Titanic 12 that I already have seems viable.
Has anyone worked out a crossover at or around 1Khz for the Delta 12?
Wishing everyone a save and joyful holiday,
Scott
Re: revisiting the Delta 12LF [message #18344 is a reply to message #18342] Tue, 20 December 2005 20:18 Go to previous message
I have a 1kHz crossover you can use. It's designed for use with a 1" compression driver on a 6" long horn. Send me your E-Mail address if you're interested.
Previous Topic: folded voight pipes???
Next Topic: Predicting The Effects Of Grille Cloth ???
Current Time: Fri Nov 13 08:01:46 CST 2026
