Audio
Does anyone have a small format Altec compression driver handy?
message #17821
Fri, 13 May 2005 11:49
wunhuanglo
May 2009
If you do, I'd appreciate if you could post the C-C measurement of the stud bolts?
Thanks very much for any help.
Charlie
Re: Does anyone have a small format Altec compression driver handy?
message #17822
is a reply to
message #17821
Fri, 13 May 2005 12:28
Manualblock
May 2009
I get 3" exactly on an 802.
Re:thanks very much! -t
message #17824
is a reply to
message #17822
Fri, 13 May 2005 16:31
wunhuanglo
May 2009
-t
first set of measurments
Array vs Horn
Thu Nov 05 01:00:15 CST 2026
