Home » Audio » Speaker » Discontinuity in horn : is it important ?
Discontinuity in horn : is it important ? [message #17669] Wed, 23 March 2005 12:34 Go to next message
Eric Mainardi is currently offline  Eric Mainardi
What seems to me worthy (IMHO) in round (tractrix) horns is that you are able to perfectly match the horn to the driver throat in producing the same angle : all compression drivers have a conical output with some angle and you can start your horn with this angle. So there is strictly NO discontinuity.
Some spectral measurements we were able to achieve show that any discontinuity in a horn expension generates standing waves and turbulences..., I mean distortion.
Meanwhile, some high end wood horns (TAD, FOSTEX, MARTINELLI,...) show a clear discontinuity at the output of the adapter (the metal piece where the driver is bolted to).
So, my friends, do you attach some importance to this point or is it a "wrong" problem ?
Re: Discontinuity in horn : is it important ? [message #17670 is a reply to message #17669] Wed, 23 March 2005 20:47 Go to previous messageGo to next message
There is a terminus at both ends of all horns. An infinite horn is a theoretical thing. You can radius the edge to meet the baffle if you like, and you can match the entry of the horn to the built-in flare of the compression driver. Sometimes this makes a big difference, sometimes not. Best to model the horn and see, or measure a physical model if you have one available.
Re: Yes [message #17672 is a reply to message #17669] Thu, 24 March 2005 20:42 Go to previous message
I thought I had addressed this problem by making the conical throat piece. By using this throat, there is an exact match to to the driver which allows for some horn expansion before being blended into the rectangular part of the horn. Where as, like you say many square horns have immediate transitions from round to square. We worked to overcome that problem.
Bill
Previous Topic: Large Heils & Hi-Vi M8A's
Next Topic: Repeated JVC Question
Current Time: Wed Nov 04 00:34:59 CST 2026
