Home » Audio » Speaker » Is This Possible ?
Is This Possible ? [message #17426] Sat, 22 January 2005 00:14 Go to next message
Ka7niq is currently offline  Ka7niq
Could someone place a rubber gasket over the threads of a compression driver to alter the extent it goes into its horn throat ?
What would this do to the sound ?
Would it change it, and if so, which way ?
Of course, one could only move the driver "back" from its throat, and go too far, it falls out.
Ever try this ?
An old roadie says they used to do it ?
The first thing I think of... [message #17429 is a reply to message #17426] Sat, 22 January 2005 07:59 Go to previous messageGo to next message
-Is when small dimensions are involved,like a few mm more spacing than normal- are HF muckups and reflections ruining the tiny[high frequency]waves !
Actual experience and changes in the sound character,perhaps some one can comment on.
Cheers
Mike.e
Re: Is This Possible ? [message #17443 is a reply to message #17426] Sat, 22 January 2005 22:06 Go to previous messageGo to next message
DaWoofer is currently offline  DaWoofer
You sure geet around! How ya been lately?
Re: Is This Possible ? [message #17479 is a reply to message #17443] Mon, 24 January 2005 17:11 Go to previous message
I like it here, kind of a "kindler, gentler board" if you know what I mean ?
Previous Topic: System impedence
Next Topic: Pro Acoustics Speakers???
Current Time: Fri Oct 16 22:59:38 CDT 2026
