Home » Audio » Speaker » 6.5" Woofer
6.5" Woofer [message #17396] Sat, 15 January 2005 19:35 Go to next message
Joe Cool is currently offline  Joe Cool
Im looking for a 6.5 inch woofer
Has to be more than 100 watts RMS
And frequency response between 100hz - 2khz
Re: 6.5" Woofer [message #17399 is a reply to message #17396] Sat, 15 January 2005 21:44 Go to previous messageGo to next message
Hi Joe,
There are many 6.5"ers around that are >100WRMS and will cover 100Hz-2KHz. Can you be more specific in what you actually need, eg: high or low efficiency, Qts values, etc. And what do you intend to use it for (horn, reflex, TL, etc)?
Adrian
Re: 6.5" Woofer [message #17403 is a reply to message #17396] Sun, 16 January 2005 11:29 Go to previous messageGo to next message
Would this be what you're lookiong for?
Two other options [message #17404 is a reply to message #17403] Sun, 16 January 2005 11:41 Go to previous message
Maybe the Eminence LA6MB or the Seas W18EX001.
Previous Topic: anyone know build this horn?
Next Topic: crossovers Gamma 15 + 4540ND
Current Time: Tue Nov 03 08:11:54 CST 2026
