Home » Audio » Speaker » Speaker producing Light Show
Speaker producing Light Show [message #17315] Sat, 08 January 2005 16:38 Go to next message
HaknHendrix is currently offline  HaknHendrix
I have a pair of 4 Pi Towers loaded with Delta 15 Pros using an Eminence PXB2-1k6 crossover. My son noticed that there was light emanating from the back of the speakers thru the ports.
When the system is cranked up, the fuse lights up on the crossover network like a light bulb - what is up with that?
Hakn
Re: Speaker producing Light Show [message #17317 is a reply to message #17315] Sun, 09 January 2005 03:13 Go to previous message
That's the way it works. The bulb acts as a limiter by increasing resistance when it ges hot from high current passing through it. If current becomes excessive, the bulb will open, protecting the tweeter.
Previous Topic: Array soundstage
Next Topic: Light Show from Speaker Port
Current Time: Fri Nov 06 20:49:48 CST 2026
