Home » Audio » Speaker » Last question, I promise! (I'm lying)
Last question, I promise! (I'm lying) [message #17297] Mon, 03 January 2005 18:40 Go to next message
Floyd Andrews is currently offline  Floyd Andrews
Is there a sonic penalty to be paid for using an adaptor to attach a 1" mouth compression driver to a 2" throat horn? I've got the 1" Altec 902 drivers, and a pair of 1" to 2" adaptors, and now I'm looking at horns. I'd like to try crossing over at a frequency somewhere between 500-800, which means 2" throat horns, from what I've seen. What say you all?
Re: Last question, I promise! (I'm lying) [message #17298 is a reply to message #17297] Mon, 03 January 2005 22:12 Go to previous messageGo to next message
GM is currently offline  GM
?? Altec bolted these to the 511B crossed at 500-800Hz/2nd order or to the 811B for 800-1200Hz/2nd order, no adapters required. WRT using adapters, unless the joints are seamless they add another discontinuity to cause HF reflections back to the throat, so unless you have a specific lens you need for your app I recommend using the ones they were designed for and damp them to suit (at least the bells).
GM
Re: Last question, I promise! (I'm lying) [message #17301 is a reply to message #17297] Tue, 04 January 2005 16:02 Go to previous messageGo to next message
I agree with GM in that adapters are usually a compromise. But it is essentially just another short flare section, so it isn't necessarily bad. Model it or measure it to be sure.
Re: Last question, I promise! (I'm lying) [message #17302 is a reply to message #17297] Wed, 05 January 2005 08:21 Go to previous message
I don't think it'll hurt going from a 1" driver opening to a 2" horn throat through an adapter is going to matter. It's when your going the other way that could cause problems.
Bill W.
Previous Topic: Open baffle Focussed Line Arrays
Next Topic: Do more sensitive drivers offer less distortion at "normal" listening levels?
Current Time: Thu Nov 26 12:46:26 CST 2026
