Home » Audio » Speaker » Help! L-Pads? Save me from a "senior moment"
Help! L-Pads? Save me from a "senior moment" [message #16993] Sun, 19 September 2004 15:42 Go to next message
Floyd Andrews is currently offline  Floyd Andrews
Greetings!I can't remember which connections to an L-pad go where. Can someone please tell me how to connect terminals 1, 2 and 3?
Re: Help! L-Pads? Save me from a "senior moment" [message #16994 is a reply to message #16993] Sun, 19 September 2004 16:13 Go to previous messageGo to next message
Ralph is currently offline  Ralph
Connect pin 3 to the input, 2 to the output and 1 is common. That's for L-Pads that have two internal pots. If you have just one pot then make the input go across the pot and the output across the wiper.
Ralph
Thanks, Ralph! (NT) [message #16997 is a reply to message #16994] Fri, 24 September 2004 16:47 Go to previous message
Thanks for the info.
Previous Topic: beyma
Next Topic: Iowa 2004 DIY Event, Saturday, October 23rd...
Current Time: Fri Nov 06 22:57:47 CST 2026
