Home » Audio » Speaker » Electro Voice EVM12L
Electro Voice EVM12L [message #16949] Thu, 09 September 2004 09:52 Go to next message
Cogs is currently offline  Cogs
I am bidding on EVM12L woofers to and I am looking for specs and cabinet ideas. Suggestions anyone?
Re: Electro Voice EVM12L [message #16951 is a reply to message #16949] Thu, 09 September 2004 10:44 Go to previous messageGo to next message
gazzamongo is currently offline  gazzamongo
evm12l specs :-http://www.thielesmall.com/include/details.asp?ID=2668&dtype=1
and the rest
http://www.thielesmall.com/database.asp
look at volvotreters mid bass horns and also edgar show horn in downloads section
cheers
gazza
Depends what you plan to do with them [message #16952 is a reply to message #16951] Thu, 09 September 2004 12:57 Go to previous messageGo to next message
They're fabulous drivers but be sure they are correct for your intended application. In a direct radiator box they are great guitar speakers or even hi-fi mid basses, but useless below 80 Hz. In a horn they can be good down to 30Hz or so, but it's going to take a big box (20 cu ft) to get that low. Edgar's Show Horn works down to about 50Hz, but the folding geometry limits the high end to 400 Hz and response is ragged; there are better choices.
WoW! [message #16955 is a reply to message #16951] Thu, 09 September 2004 13:44 Go to previous messageGo to next message
pokey1 is currently offline  pokey1
WoW!
Good lookin horns!
I think I've seen m before but still say wow.
Thanks for the link too. It deserves a plug so I think I'll do that now.
Re: Depends what you plan to do with them [message #16957 is a reply to message #16952] Thu, 09 September 2004 13:52 Go to previous messageGo to next message
Do you have a response chart of Edgar's Show Horn with EVM15L?
Thanks in advance.
Re: Depends what you plan to do with them [message #16958 is a reply to message #16957] Thu, 09 September 2004 13:53 Go to previous messageGo to next message
I mean EVM12L. Sorry for any confusion.
Re: Depends what you plan to do with them [message #16960 is a reply to message #16958] Thu, 09 September 2004 15:30 Go to previous messageGo to next message
its all there in the download section on volvotreters site.
gazza
thanks! nt [message #16961 is a reply to message #16960] Thu, 09 September 2004 16:32 Go to previous message
nt
Previous Topic: Speaking of Electro-Voice,
Next Topic: High efficiency with a Purpose
Current Time: Wed Oct 21 05:02:06 CDT 2026
