Home » Audio » Speaker » TAD 2404
TAD 2404 [message #16591] Mon, 07 June 2004 14:14 Go to next message
Don Hughes is currently offline  Don Hughes
Does any of you have one of these? Have any of you made something like it?
Re: TAD 2404 [message #16592 is a reply to message #16591] Mon, 07 June 2004 17:44 Go to previous messageGo to next message
This guy has.
Re: TAD 2404 [message #16593 is a reply to message #16592] Tue, 08 June 2004 04:43 Go to previous messageGo to next message
greenback is currently offline  greenback
beautiful wood horns. did you see the speakers he makes? tad clones, single driver speakers and wood horns for gauss coax drivers. prolly sounds awesome.
lookie [message #16594 is a reply to message #16593] Tue, 08 June 2004 04:55 Go to previous messageGo to next message
This is Yuichi's Left side main Stereo Speaker System.
Up to bottom:
A-290 Horn + JBL-2441 Driver (600-8KHz)
A-190E Horn + Electro Voice EVM-10M (250-600Hz)
A-2000 horn + Pioneer TAD TD-2001 Driver (8K-20KHz)
280L Enclosure + JBL-2245 (20-250Hz)
Re: TAD 2404 [message #16596 is a reply to message #16592] Tue, 08 June 2004 15:03 Go to previous messageGo to next message
Have you heard any of his speakers?
Re: TAD 2404 [message #16597 is a reply to message #16596] Tue, 08 June 2004 17:38 Go to previous message
No sir. Never been west of LA. But he's more than a little famous for his work.
Previous Topic: How close can you sit to a frontloaded bass horn without compromise?
Next Topic: Fostex F-220A 55 Liter Ported Enclosure
Current Time: Fri Oct 23 06:12:47 CDT 2026
