Home » Audio » Speaker » Woofers for Martinelli horn
Woofers for Martinelli horn [message #16132] Wed, 18 February 2004 10:38 Go to next message
DaveJ is currently offline  DaveJ
Hi there,
I have a set of Bill's 800Hz Woodhorns with the PSD-2002 drivers and I'm looking to build a suitable set of woofers to match. Any suggestions on an SET friendly driver?
I'm thinking something in a 12" size. The room is about 1400ft^3 and going much below 40Hz is probably not needed. I'd like to keep the box under 3ft^3 or so. Listening levels are generally on the lower side so I'd like to build something that doesn't need to be cranked to sound good.
Any suggestions are appreciated.
Thanks.
DaveJ
Re: Woofers for Martinelli horn [message #16135 is a reply to message #16132] Wed, 18 February 2004 16:51 Go to previous messageGo to next message
12" drivers, Eminence Alpha 12 works well on SET.
Perhaps look at something better though like the Delta 15 or JBL 2226, they are 15" drivers though.
Re: Woofers for Martinelli horn [message #16139 is a reply to message #16132] Thu, 19 February 2004 15:00 Go to previous messageGo to next message
DRC is currently offline  DRC
Dave,
You might want to post this on the Pi forum here.
Hardly an expert but [message #16140 is a reply to message #16132] Thu, 19 February 2004 16:09 Go to previous message
I wouldn't worry about size, I'd worry about efficiency.
These are pretty sweet for the price.
Previous Topic: 1.25 cu upgrades
Next Topic: Check this out!
Current Time: Sun Oct 18 05:07:50 CDT 2026
