Home » Audio » Speaker » anyone try matching a 40"ribbon tweeter and a 15" woofer
anyone try matching a 40"ribbon tweeter and a 15" woofer [message #16001] Wed, 07 January 2004 09:57 Go to next message
Zeno is currently offline  Zeno
thanks
Re: anyone try matching a 40"ribbon tweeter and a 15" woofer [message #16002 is a reply to message #16001] Thu, 08 January 2004 10:36 Go to previous message
I have no experience with ribbons
but
since no one else has replied yet-
appropriate filtering must be used.
-high enough order
-correct Fc
-phase controls?
-Enough knowledge to use /design the filter system taking into account transducers being used.
The 15" woofer
-must be a low distortion type
-good alignment of flat or overdamped response 'non boomy '
as im sure that ribbons demand the best quality.
Woofer distortions extending into the midrange will destroy the entire sound.
see www.linkwitzlab.com -thor subwoofer.
Cheers!
Previous Topic: Fresnel and fibonacci line array systems
Next Topic: Klipschorns anyone?
Current Time: Tue Nov 03 10:17:04 CST 2026
