Home » Audio » Speaker » old cabinets
old cabinets [message #15446] Mon, 15 January 2007 08:14 Go to next message
hamburgerman is currently offline  hamburgerman
I bought these old pa cabinets off ebay they are 15's with horns made by Woodson cousin co. of kustom the horns are metal and these things bark! my question is, how can I tell how much power they will take, so I don't overload them. I am using a 300 watt per. side amp now and want to upgrade. Thanks Rob
Re: old cabinets [message #15447 is a reply to message #15446] Mon, 15 January 2007 09:25 Go to previous messageGo to next message
It isn't immediately obvious how much power a speaker will take. You can run the power up and measure when it starts to enter compression, that will give you some idea. You will need to have some test equipment to do this though.
Re: old cabinets [message #15449 is a reply to message #15446] Mon, 15 January 2007 17:56 Go to previous message
I was looking at 600 peak a side amp . hope not to blow em but I don't crank it too much.
Previous Topic: ProAC 2.5 Clone Project
Next Topic: Line Arrays At CES
Current Time: Tue Nov 03 13:37:14 CST 2026
