Home » Audio » Speaker » what are the best small compact speakers you would suggest?
what are the best small compact speakers you would suggest? [message #15363] Wed, 30 August 2006 19:50 Go to next message
aromes is currently offline  aromes
I would prefer small compact speakers that:
(1)delivers enough good quality clear loud sounds for a motel room...one that kicks out some superb sounds
(2)That's under $50
(3)that is small and compact so that I can easily pack it in my laptop's case
Also:
Are the wooden Mini Travel Speakers at this site: http://www.iwantoneofthose.com/travel-speakers/index.html
...the same as premiertek's Sound Pod Fold Up Amplified Portable speaker? If Yes, what do you think of them as small quality speakers?
What do you think of these 2 speakers:
-Logitech R-10 Multimedia Speakers $29 at futureshop?
2 x 2 Watts
-Creative Labs Vivid 80 Speakers (MF5005)
Thanks
Re: what are the best small compact speakers you would suggest? [message #15364 is a reply to message #15363] Thu, 31 August 2006 06:37 Go to previous message
Sonic T-Amp and Triangle Speakers. 79$ Less on sale.
Previous Topic: OPen baffle designs
Next Topic: Any ESL owners here?
Current Time: Sat Oct 17 03:06:20 CDT 2026
