Home » Audio » Speaker » I need to locate a custom speaker builder/company or someone to just exchange a coil for me
I need to locate a custom speaker builder/company or someone to just exchange a coil for me [message #15098] Mon, 05 September 2005 15:34 Go to next message
Matthew is currently offline  Matthew
I need someone to modify a couple of speakers I have with faraday rings
this is more or less something I'm looking to do in the next couple of months not necessarily right now
I need a person... fairly easy to talk specifics with (nobody hard to reach and such) that can add compensating coils to 4 speakers...
TC sounds is the only place I know of which does this kind of work... but now that the forum dude is not working there I can't seem to get ahold of anyone
anybody know a person or know of someone with enough knowledge to swap the coil?
Re: I need to locate a custom speaker builder/company or someone to just exchange a coil for me [message #15099 is a reply to message #15098] Mon, 05 September 2005 16:50 Go to previous message
Are you going to remove the magnet and modify it, adding a shorting ring? Or are you planning to work on the voice coil?
If the former, you need a machine shop. If the latter, a place that does recones can do the work for you.
Previous Topic: Fostex 167E distortion
Next Topic: I need to locate a custom speaker builder/company or someone to just exchange a coil for me
Current Time: Thu Oct 15 06:28:00 CDT 2026
