Home » Audio » Speaker » IN WALLS ???
IN WALLS ??? [message #15025] Sat, 04 June 2005 09:30 Go to next message
djm is currently offline  djm
I want to use in walls for my home theater. I will be using them
also for video games and backround music to. I need to find an in wall
that is very easy on the ears but very detailed and nice. I want to
feel as I am in the game it self or in the movie. If there is not
an in wall like this is there a diy kit I can do or that you know of?
please e-mail me and tell me what you think as well as what you have
used and I also need for it to have ajustable switchs for the sound.
Thanks jm
Re: IN WALLS ??? [message #15026 is a reply to message #15025] Sat, 04 June 2005 12:01 Go to previous messageGo to next message
How much depth do you have to work with? I'll be finishing my basement in a few months, and I going to run into the same issues. Luckily, the walls will be pulled out about 10" from the foundation; so, I am considering using the Pi 1s in the walls beside the TV and possibly the ceiling. The bass will be filled in by a dedicated sub.
If you are going between 2x4 studs and have limited depth, look over at the Parts Express "Tech Talk" forum and see what these guys are using for smallish 2-ways. A small, decent sounding 2-way can be built for
Here ya' go [message #15027 is a reply to message #15025] Sat, 04 June 2005 15:43 Go to previous message
They're downright expensive, though.
Previous Topic: Finished At Last
Next Topic: Initial imprssion of the Audio Nirvana 6,5
Current Time: Fri Nov 27 11:05:21 CST 2026
