Home » Audio » Speaker » Does anybody here know how to add and subtract?
Does anybody here know how to add and subtract? [message #14916] Tue, 05 April 2005 17:30 Go to next message
For the life of me, I can't seem to.
I've been trying to figure out resistive damping of dual voice coil woofers.
First I went to Adire:
http://www.adireaudio.com/Files/TechPapers/RDOOperation.pdf
I put the eq.s into Excel, but the higher the damping resistor, the closer you get to the original Qts and no higher. At Rl=0 the Qts is halved (more or less)
Then I went here:
http://www.geocities.com/kreskovs/Dual-VC.html
Same story. Either there's something fundamentally wrong with the eq.s as written, or I'm so far out in left field I cant see the plate from here.
Has anybody fooled with this before?
Re: Does anybody here know how to add and subtract? [message #14918 is a reply to message #14916] Tue, 05 April 2005 17:42 Go to previous messageGo to next message
When you short the voice coil, you increase damping. That makes Qts go down. When the voice coil is open, it has no effect, no change on Qts. When you partially short it, as in putting a resistor across it of a few ohms, it is in between.
This is in parallel with the output impedance of the amplifier. Less impedance makes more damping, lower system Q. Higher output impedance makes less damping, higher total Q.
Well, dammit... [message #14920 is a reply to message #14918] Tue, 05 April 2005 20:37 Go to previous messageGo to next message
that's exactly what the equations say, that's exactly what I calculated.
Thanks, Wayne.
But if you read the references they claim the exact opposite - they talk about doubling Qts with a couple of hundred ohms across a second 8 ohm coil. From the Adire paper:
"It allows you to vary the Qts of the driver over a range of nearly 2 to 1, from the "nominal" Qts up to nearly double that value."
How can they get it so 180 out?
Re: Well, dammit... [message #14923 is a reply to message #14920] Wed, 06 April 2005 04:21 Go to previous messageGo to next message
Perhaps what they're calling the nominal value is with the voice coil shorted, then double is with it open.
Unfortunately.... [message #14927 is a reply to message #14923] Thu, 07 April 2005 01:57 Go to previous messageGo to next message
still a mystery.
I did some considerable web crawling on this and I have Adire's engineer saying explicity that the technique allows you to double the driver Qts, going from 0.38 with both coils driven to 0.76 with one coil driven and one coil shorted with the appropriate resistance.
There just doesn't seem to be any way that's possible given the derivation I found, which looks pretty consistent to me (but dynamics was never my long suit).
Re: Unfortunately.... [message #14928 is a reply to message #14927] Thu, 07 April 2005 04:52 Go to previous message
Very interesting. I'll look over this. My first thought is that shorting a second coil would act much like shorting a single voice coil does, increasing damping and lowering Qts. But maybe shorting a second voice coil increases stiffness like using a small sealed box. Thanks for bringing this to my attention, it is interesting and I'll look into it.
Previous Topic: Altec 902 / Edgarhorns: compensation experiments
Next Topic: mackintosh xrt 29
Current Time: Fri Oct 23 09:43:15 CDT 2026
