Home » Audio » Speaker » large or small?
large or small? [message #14485] Wed, 07 January 2004 00:31 Go to next message
Andrew is currently offline  Andrew
Hi
I have a 100RMS (stereo), 80RMS (5.1 channel) amplifier. I am looking at two different set of speakers:
1. 80 RMS/max 120 x 2 (Main), 35/60 RMS (Centre) and 30/60 RMS x 2 (Rear) at 4ohms
OR
2. 100rms/max 150 x 2 (Main), 40/80 RMS (Centre) and 35/80 RMS x 2 (Rear) at 8ohms
(this second specification is quoted as the above and then in other places as 150RMS each speaker, which I doubt.
Which do you think I should go for?
Thanks in anticipation.
Andrew
Re: large or small? [message #14486 is a reply to message #14485] Wed, 07 January 2004 06:03 Go to previous messageGo to next message
What are the rest of the specs? Honestly, if you use just those numbers, you'll be making a pretty ill-informed decision. See if you can post some more information, and I'll bet you'll get some good advice here.
Re: large or small? [message #14487 is a reply to message #14485] Sun, 11 January 2004 05:42 Go to previous message
Scott L is currently offline  Scott L
the speakers' "amount of watts" mean nothing in particular.
i almost hate to say it, but: bigger is better; especially the hi-effeciency types.
i'd urge you to learn more in general, about speakers.
Previous Topic: Klipschorns anyone?
Next Topic: Updated my horns page..
Current Time: Tue Nov 03 07:46:12 CST 2026
