Home » Audio » Source » Hey Wayne, what's up with this gizmo?
Hey Wayne, what's up with this gizmo? [message #14335] Sun, 24 September 2006 12:34 Go to next message
lon is currently offline  lon
I just saw this thing at Tiger Direct. No clue as to whether it's
worth the dough but it has solid 5 star reviews from buyers.
Is this just black box snake oil or what?
I figured you'd know a scam from an actual functioning device.
True that the software content is unknown, but I've put off ripping
LP's for a long time due to setup problems and quality of
sound. For instance, the review info says the software will
split tracks. I have Audiograbber which is supposed to do
that but it never worked right.
Re: Hey Wayne, what's up with this gizmo? [message #14336 is a reply to message #14335] Mon, 25 September 2006 00:16 Go to previous messageGo to next message
It's just an ADC designed to connect using a USB port. The price isn't bad, so I don't think there's any harm checking it out. Let us know what you think if you get one.
Re: Hey Wayne, what's up with this gizmo? [message #14337 is a reply to message #14336] Sat, 30 September 2006 14:12 Go to previous message
Well, unless there's a Krugerand inside it, anything that small
isn't worth 60 balloons. But it might go on deal at TigerDirect.
My home studio is still a long way from completion. A toy like that
would be somewhere in my future when the turntable is set up.
Previous Topic: Technics SL-B2
Next Topic: Whatever happened to MiniDiscs?
Current Time: Thu Nov 05 21:42:57 CST 2026
