Home » Audio » Source » dvd mod/upgrade
dvd mod/upgrade [message #14294] Wed, 15 February 2006 10:44 Go to next message
Guest is currently offline  Guest
Hi I am new here. Is there a way to mod a dvd player to get it to play different formats such as flac and ogg? I have a cheapo Philips dvd player that already play divx and xvid, mp3, etc. Does anyone know if a chip need to be replaced or firmware written specifically for certain models? Any info would help. Thanks
Re: dvd mod/upgrade [message #14295 is a reply to message #14294] Wed, 15 February 2006 10:46 Go to previous messageGo to next message
I also have another dvd player that does not play divx. Is there a way to get it to play divx?
Re: dvd mod/upgrade [message #14296 is a reply to message #14295] Sat, 18 February 2006 09:37 Go to previous message
You would have to change the firmware, which is usually contained inside a ROM. Unless someone has an upgraded ROM (or flash update) available, this is a non-trivial matter. Basically, you should probably look into buying a new player, one that reads the disks you want to use.
Previous Topic: Old vinyl
Next Topic: Manualblock
Current Time: Thu Nov 26 07:49:48 CST 2026
