Home » Audio » Source » Sony TC-650 reel deck brakes
Sony TC-650 reel deck brakes [message #13900] Tue, 20 February 2007 18:19 Go to next message
Larry Sturtz is currently offline  Larry Sturtz
Subject deck works well except when stopping in mid-rewind.Left hand takeup reel stops smoothly but right hand reel continues in motion unspooling 12+ inches of tape before stopping. When the tensioner resets it usually, but not always, breaks the tape.
Have cleaned reel hub and inspected brake and cleaned brake pads. Any direction on how to fix?
Re: Sony TC-650 reel deck brakes [message #13901 is a reply to message #13900] Wed, 21 February 2007 09:31 Go to previous messageGo to next message
Are parts available for this deck still? If so, I'd check the brake solenoid and replace the brake pads if necessary.
Re: Sony TC-650 reel deck brakes [message #13902 is a reply to message #13900] Tue, 06 March 2007 14:41 Go to previous message
slbender is currently offline  slbender
Hi,
I have most parts for the TC-650 ( one got destruyed in shipping on its way to me from Florida. The brake pads are probably worn, or the spring tensioner needs to be set at a higher level. These things can be checked by taking the front panel off and operating the set.
-Steven L. Bender
Previous Topic: ALLEGRO ZENITH STEREO CONSOLE
Next Topic: Idler Drive and my Rek-O-Kut project
Current Time: Fri Nov 27 05:41:06 CST 2026
