Home » Audio » Source » Pioneer RT - 707 woes (wows)
Pioneer RT - 707 woes (wows) [message #13850] Fri, 03 February 2006 10:18 Go to next message
MOGUL is currently offline  MOGUL
HI,
I have a mint condition Pioneer RT – 707. I know one of the specs for these decks used to be wow and flutter. Wow does it have wow - almost slows to a halt at times and lots of chipmunks at either speed. FF and Rew seem to be OK although rewind tends to spill a little tape. Previous owner says he hasn’t used it in a while and says “the wheels may need lubricating” but forgets how to do it. No manual. Can anyone help?
Thanks,
John
Re: Pioneer RT - 707 woes (wows) [message #13851 is a reply to message #13850] Fri, 03 February 2006 14:17 Go to previous messageGo to next message
You need a speed adjustment, and you may also need a pinch roller. It's possible you may need a motor or two. If you're comfortable working on the deck, pick up a service manual at StereoManuals.com and perform the adjustments prescribed. Pinch rollers were still available from Pioneer last time I checked, which was about two years ago. Mine had become jelly bears, so I bought a new one and a couple extras to keep on hand.
Re: Pioneer RT - 707 woes (wows) [message #13852 is a reply to message #13851] Sat, 04 February 2006 11:13 Go to previous message
Thanks Wayne. I'm looking into these things.
John
Previous Topic: turntable surface noise in right channel
Next Topic: Problems with turntable's ground wires, help needed.
Current Time: Wed Nov 04 11:07:33 CST 2026
