Home » Audio » Source » 58 Crown Imperial Tape Recorder
58 Crown Imperial Tape Recorder [message #13827] Thu, 24 February 2005 10:58 Go to next message
Jamie Mastrio is currently offline  Jamie Mastrio
Hi,
I have an old 1958 Crown Imperial tape recorder that I want to try to fix so I can transfer some old tapes to MP3. Right now, once the thing warms up it makes a horribly loud HUMMMMM noise.
I have the original instruction manual that shows the schematic, but was wondering if anyone knows where I can get spare parts for this thing? Can I just purchase tubes from any place? Also, the electrical cord on this thing is about to turn into dust and must be a fire hazard, any thoughts on how/where I can get a new one?
Thanks for any help in this mattter!
Jamie
Re: 58 Crown Imperial Tape Recorder [message #13828 is a reply to message #13827] Thu, 24 February 2005 12:21 Go to previous message
It's nice that you have the schematic. You might restore it to new condition with that. Tubes are still available from several companies, and you'll probably need to replace the capacitors as well. In fact, there's a good chance that the tubes are fine and that your only problem is old capacitors that have leaked and gone bad.
Previous Topic: technics sl-1600 outputs in mono (please help!)
Next Topic: Do I need a Phono pre-amp box???
Current Time: Thu Nov 12 03:38:04 CST 2026
