Home » Audio » Source » Yamaha YP-B2 Turntable Cartridge/needle?
Yamaha YP-B2 Turntable Cartridge/needle? [message #13750] Wed, 25 March 2009 04:04 Go to next message
jonjbayarea is currently offline  jonjbayarea
I recently purchased a Yamaha YP-B2 in absolutely perfect cosmetic condition.
After bringing it home I realized that it needed a new belt, which I replaced.
I dont know how old the needle on it is and am thinking of of replacing it.
Can anyone tell me what kind I need?
Can someone recommend something good at about $50-$60?
Sorry if im not using correct terminology, I really dont know much about this sort of thing.
Thanks!
Re: Yamaha YP-B2 Turntable Cartridge/needle? [message #13751 is a reply to message #13750] Fri, 27 March 2009 11:51 Go to previous message
You can get them at NeedleDoctor.com. If you need just the needle, you'll need to identify the cartridge. Or you can replace the whole cartridge, which includes the needle. Either way, they can help you out.
Previous Topic: CAL Icon CD player
Next Topic: need turntable
Current Time: Thu Nov 05 19:24:59 CST 2026
