Home » Audio » Source » Turntable amp for Harmon/Karmon AVR 135
Turntable amp for Harmon/Karmon AVR 135 [message #13567] Thu, 25 October 2007 10:47 Go to next message
Ron Sparks is currently offline  Ron Sparks
I have a harmon/Karmon AVR 135 and need an turntable amp.
are there any recommendations as to which one to buy??
Also have a Technics SL-220 and Htachi HT-350 turntables, which is the best to use??
Thanks
Ron
Re: Turntable amp for Harmon/Karmon AVR 135 [message #13568 is a reply to message #13567] Thu, 25 October 2007 11:30 Go to previous messageGo to next message
Y. Kang is currently offline  Y. Kang
http://www.amazon.com/Pyle-PP-999-Phono-Turntable-Pre-Amp/dp/B00025742A
this was cheap and it worked well.. i also sent u this link via email
Y. Kang
Re: Turntable amp for Harmon/Karmon AVR 135 [message #13681 is a reply to message #13567] Tue, 03 June 2008 00:21 Go to previous message
Passing By is currently offline  Passing By
Ron,
Just stumbled on this, I have a Pioneer DSX D912 and an old Technics turntable and purechased a DJ PREII phone preamplifier that works great and can be picked up for less than $75.00. If you want to check it out, go to www.artproaudio.com. The specs should match up for your needs and its well made compared to less expensive phone preamps you can buy. I purchased mine at a musical instrument store that sold DJ equipment. Hope it helps
Wayne
Previous Topic: SL-QD33
Next Topic: Sound quality - platter speed
Current Time: Fri Apr 19 21:03:15 CDT 2024
