Home » Audio » Source » Anti-skate weight replacement for Yamaha YP-701
Anti-skate weight replacement for Yamaha YP-701 [message #13391] Fri, 18 May 2007 20:26 Go to next message
Jim G is currently offline  Jim G
I have resurrected an old Yamaha YP-701 turntable but over the years the anti-skating weight has gone missing. The anti-skating mechanism is the type where a weight is attached to an anti-skating shaft, which applies a tracking force of between 1 gram and 3 grams depending on where on the shaft the weight thread is attached.
Does anyone know what weight in grams I should use as a replacement anti-skating weight? (I thought maybe it should be 3 grams to match the max tracking force of the mechanism??).
Thanks
Re: Anti-skate weight replacement for Yamaha YP-701 [message #13450 is a reply to message #13391] Mon, 23 July 2007 19:26 Go to previous message
lighty is currently offline  lighty
I recently aquired one of these. It looks like the included anti-skate weight is original. Digital stylus force guage measures it at 2.92 grams so it appears your assumption was correct.
Previous Topic: Warped sounding: not the album, platter or belt...what is it??
Next Topic: First Turntable
Current Time: Thu Nov 05 08:27:25 CST 2026
