| What are the common issues that you've experienced with using different tube amps? [message #99486] |
Fri, 05 June 2026 13:20  |
Kurt
Messages: 38 Registered: December 2025
Baron |
I would like to know various challenges that some of us have had while using different tube amps. Currently, I make use of Evo 400, Mclntosh MA352 hybrid, and the Rogue Audio Cronus Magnum III.
I am the type that likes having different options when it comes to vacuum tube amps, but I've experienced different challenges while using these amps. For example, I always feel an increase in heat in the room when I switch from Rogue to Evo 400. That meant that I am always careful of the one to use depending on weather conditions.
So, I would like to know if anyone here run multiple tube amps and what issues you've encountered while using them?
Is there a good tip on how to manage heat, and how do you get along with managing running multiple amps?
| Re: What are the common issues that you've experienced with using different tube amps? [message #99672 is a reply to message #99643] |
Sat, 08 August 2026 21:29  |
gofar99
Messages: 2059 Registered: May 2010 Location: Southern Arizona
Illuminati (5th Degree) |
Hi, since I half own half of the company...I didn't pay anything for them. The amps in the photo were ruggedized models we used at demonstrations. Electrically they are the same as the kits. The kits at that time were around $700 less tubes. Unfortunately that even though the company still exists it is hibernating. COVID did a number on our suppliers and fabricators. To continue now the prices would have to be around double. Diy is still viable and I am happy to provide assistance with anyone who does that. (gofar99@hotmail.com)i
