Home » Audio » Speaker » How do you find the right gears like amps for your speakers without making a mistake? (I lost money trying to do this.)
How do you find the right gears like amps for your speakers without making a mistake? [message #99416] Fri, 15 May 2026 22:56 Go to next message
Cole is currently offline  Cole
I was once a victim of this as I once spent around $9,500 on a Class A without getting the result that I wanted when I matched it with the speakers. The reviews and the specs of the amp were really impressive, but when I decided to purchase it, it couldn't deliver on my Focal Utopia III Evo speakers.
I was so excited when I spent that kind of money on an amp because I was hopeful that I am about to experience playing songs and watching movies on a different wavelength, but I realised that I was wrong as the speakers and the amp couldn't synchronise at all.
My thinking has been that most expensive amps can work on most speakers, but that experience proved me wrong. So, I wouldn't want to keep swapping amps and speakers praying to find the one that works because it is a way to waste money. Rather, does anyone have an idea of what actually works without guessing?
How does one get to figure that out? I am talking about what actually worked for anyone here based on their experience.
What should I always check when getting amps for my speakers?
Re: How do you find the right gears like amps for your speakers without making a mistake? [message #99418 is a reply to message #99416] Mon, 18 May 2026 00:14 Go to previous messageGo to next message
George is currently offline  George
It's quite unfortunate you had such an experience. The reality is that getting expensive gear doesn't mean it can match your musical equipment. This has a lot to do with synergy and little about specs.
What I do when buying amps is that I test it before I make purchases, depending on the speaker that I am getting it for. For example, the Focal III Evo that you mentioned is 4 ohm, 92dB sensitivity, and leans bright. This means, talking from experience, that it needs amps that have clean power, control, and a neutral tone to avoid harshness.
So, I think that understanding the type of speaker that you have and its features can always help you in making the right decisions when it comes to getting the amps that match it. It doesn't have to be an expensive amp, but if you find one, that's still fine.
Re: How do you find the right gears like amps for your speakers without making a mistake? [message #99420 is a reply to message #99416] Wed, 20 May 2026 08:44 Go to previous message
Prince is currently offline  Prince
Cole wrote on Fri, 15 May 2026 22:56
There are certain amps that I've seen work better with certain speakers. The Focal Utopia III Evo has always had a great combo with the Mclntosh MA12000 and Accuphase E-5000.
You should try both if what you've got is not giving you the desired result.
It is important to know the sensitivity of your speakers before getting amps. I know that low sensitivity speakers will always need more watts and vice versa. So, ensure you have an idea of the type of speaker that you've got before going for any amp.
Previous Topic: What has been your experience on Bose SoundLink Max?
Next Topic: What is the best Bluetooth speaker for my bathroom?
Current Time: Fri Nov 13 16:28:31 CST 2026
