Home » Audio » Measurement » emf in speakers
emf in speakers [message #98075] Sun, 17 November 2024 19:30 Go to next message
Hi everyone. Pop on the thinking caps.Typical voice coil speakers develop a voltage when they return to rest after being pulsed by audio. The spring back of the cone inside the magnetic filed will produce a voltage. This is part of the reason that amplifiers have what is known as a damping factor. It is supposed to short out the voltage to varying degrees. Higher damping factors are supposed to be better at this than lower ones. The question that occurred to me this morning was do electrostatic speakers generate an emf in a similar manner. Since they are largely capacitive (and not inductive) I suspect they might. Does anyone know?
Re: emf in speakers [message #98076 is a reply to message #98075] Mon, 18 November 2024 09:35 Go to previous messageGo to next message
I've not really studied them but as a mental exercise, I see no way that something using charged plates to move a diaphragm would have any mechanism to make them act as a generator. However, a piezoelectric driver could generate back-EMF, essentially acting like a crystal microphone.
I suppose the best verification test would be to hook one up and see if you could generate a signal by moving the diaphram.
Re: emf in speakers [message #98078 is a reply to message #98076] Tue, 19 November 2024 19:54 Go to previous messageGo to next message
Hi Wayne. A possible idea....except the panels are energized at about 1200VDC. Such a test could well end with music from the "pearly gates". Plus the actual travel distance is rather small. My general thought is that if there is back emf it will be very small. I perceive that this is likely a good thing as they will have minimal interaction with the amp and its damping factor. Possibly a really good match for ones that have low damping factors. On the negative side it seems that many ESLs similar to mine tend to act like a capacitive load on the amps and may need significant current drive particularly at high frequencies as opposed to voltage drive. Martin Logan says mine go from about 4 ohms in the low and mid band to 1.2 ohms at 20KHZ. It all makes for an interesting issue to do more study on.
Re: emf in speakers [message #98079 is a reply to message #98078] Wed, 20 November 2024 08:40 Go to previous message
Yes, a capacitive load would be tough to drive up high.
Previous Topic: How is dbv rated "A" in testing of gear
Next Topic: The best apps to measure noise levels
Current Time: Fri Sep 04 19:09:58 CDT 2026
