Home » Sponsored » Pi Speakers » four π build with JBL 2226H and 2426H?
four π build with JBL 2226H and 2426H? [message #97944] Sat, 10 August 2024 05:40 Go to next message
martinl is currently offline  martinl
Hello hello!
I am planing on building the four π speakers and found a good deal (200euros) on a pair of JBL 2426 drivers which should be an upgrade from the B&C DE250 with similar specs, they are even mentioned in the crossover schematics.
Would the four pi build benefit from these or should I stick with the DE250?
Also I would go with the 2226H woofer.
Another thing is I am having trouble ordering the 290C horns, I am located in France and the shipping price is I miscalculated I believe, setting me up at 350$ for UPS shipping!! Wowsers.
Thank you in advance,
Martin
Re: four π build with JBL 2226H and 2426H? [message #97946 is a reply to message #97944] Sat, 10 August 2024 09:18 Go to previous messageGo to next message
We used to offer the JBL 2426H as an upgrade option but discontinued it because the DE250-8 is a better sounding driver and costs less too.
As for shipping, I recommend using a freight forwarder. They will provide a USA address, which you will then use in the Pi Speakers cart, by entering the address they give you. This will make your shipping costs much lower. Do a search on the internet to find out what freight-forwarding companies are available to you in your area.
Re: four π build with JBL 2226H and 2426H? [message #97947 is a reply to message #97946] Sat, 10 August 2024 10:10 Go to previous messageGo to next message
Please ignore my mail, I didn't see your answer in time.
If you say so I will go with the B&C compressions then, also will look into freight forwarding.
Thanks for helping out!
Re: four π build with JBL 2226H and 2426H? [message #97948 is a reply to message #97947] Sat, 10 August 2024 12:30 Go to previous message
That's the best way!
Previous Topic: Help with value of 4 Pi kit/speaker
Next Topic: Insulation Alternatives
Current Time: Sun Nov 15 15:22:07 CST 2026
