Home » Audio » Speaker » Speaker Snap Banana Plugs
Speaker Snap Banana Plugs [message #97496] Sun, 10 March 2024 04:00 Go to next message
something new.
https://www.speakersnap.com
Re: Speaker Snap Banana Plugs [message #97514 is a reply to message #97496] Sat, 16 March 2024 14:16 Go to previous messageGo to next message
Well, it looks easy to use. It doesn't require a bunch of tools or pesky fiddling. Those are pluses. It's also a gold-plated connector, which is what you'd expect to see on anything decent. Do you believe it will stay hooked on/in? A tiny lever is meant to do the heavy work. I wonder if it's enough.
Re: Speaker Snap Banana Plugs [message #97515 is a reply to message #97514] Sat, 16 March 2024 21:26 Go to previous messageGo to next message
Hi, At $8 a pair I can live with ones that have set screws.
Re: Speaker Snap Banana Plugs [message #97517 is a reply to message #97515] Sun, 17 March 2024 08:27 Go to previous message
Based on the WAGO connector I'd wager.
Previous Topic: Tonies for kids
Next Topic: SBIR
Current Time: Fri Jul 17 13:28:02 CDT 2026
