Home » Sponsored » Pi Speakers » Insulation Mistake/Question
Insulation Mistake/Question [message #97246] Sat, 02 December 2023 20:31 Go to next message
DSD is currently offline  DSD
I'm so close to finishing a pair of 4 Pi, but I glued the side piece of insulation in one speaker to the wrong side of the speaker, that is, the side opposite the port. All the other insulation is glued in place, including the piece across the brace. Will this make any difference? Do I need to pull it off and glue a piece to the correct side?
Thanks
Daniel
Re: Insulation Mistake/Question [message #97247 is a reply to message #97246] Sun, 03 December 2023 08:28 Go to previous messageGo to next message
Go ahead and remove it and attach to the side nearest the port. It will peel away easily. Might leave a trace of fibers and glue lines - which might kind of "bug you" to know it's there - but that won't hurt anything and it'll stop bugging you in days. Especially after you give 'em your first audition with your favorite music. https://audioroundtable.com/images/thumbs-up.gif
Re: Insulation Mistake/Question [message #97248 is a reply to message #97247] Sun, 03 December 2023 08:44 Go to previous messageGo to next message
Ughhhh! Okay.
Daniel
Re: Insulation Mistake/Question [message #97249 is a reply to message #97248] Sun, 03 December 2023 09:30 Go to previous messageGo to next message
You're right, that wasn't bad at all. It probably does add a day for this to dry, though.
Re: Insulation Mistake/Question [message #97250 is a reply to message #97249] Sun, 03 December 2023 09:48 Go to previous message
Makes me think of the 1970s Heinz commercials:
Previous Topic: For Sale: Pi4 Speakers Upgraded XO
Next Topic: Where to get JBL 2226 Dustcap Replaced?
Current Time: Sat Jul 12 11:59:20 CDT 2025
