Home » Sponsored » Pi Speakers » Which model?
Which model? [message #96961] Sat, 02 September 2023 14:16 Go to next message
Faizal is currently offline  Faizal
The details: My room is 18 ft by 10 ft with 8 ft ceilings. Speakers will be in front of the short wall, and can be about 2-3 ft in front of them. Bass extension is not the highest priority. I can use a sub if needed.
Which Pi would work best here? Thanks!
Re: Which model? [message #96962 is a reply to message #96961] Sun, 03 September 2023 08:59 Go to previous messageGo to next message
You can use any of our models in that room. See the Pi Speakers FAQ - especially the pages that discuss differences between models and options - to help you decide which model is best for you.
Re: Which model? [message #96964 is a reply to message #96962] Mon, 04 September 2023 09:44 Go to previous messageGo to next message
Thanks! I'll have a more detailed look thru that.
One thing I hadn't noticed before: The cabinet for the 4 is actually smaller than the 3. Could you explain why this is, or just point me to any explanation that already exist? Thanks.
Re: Which model? [message #96967 is a reply to message #96964] Mon, 04 September 2023 19:13 Go to previous messageGo to next message
The box size was just a function of the tuning. You're right that the four Pi is a smidge smaller, but they're really very similar loudspeakers. The three Pi has 3dB lower voltage sensitivity, with exception of the Delta Pro 12 variant, which trades some extension for sensitivity. In all other cases, they have generally similar response with 3dB sensitivity difference.
Re: Which model? [message #96970 is a reply to message #96967] Tue, 05 September 2023 12:36 Go to previous messageGo to next message
Thanks for your responses.
Could you send me the plans for the 4 Pi?
Re: Which model? [message #96971 is a reply to message #96970] Tue, 05 September 2023 14:11 Go to previous messageGo to next message
You've got mail!
Re: Which model? [message #96972 is a reply to message #96961] Tue, 05 September 2023 15:44 Go to previous message
Very Happy
Previous Topic: It's getting to be subwoofer time.
Next Topic: Pi 8 speaker
Current Time: Sun Dec 10 16:47:30 CST 2023
