Home » Audio » Source » Technics 1200s audio from 1 channel only
Technics 1200s audio from 1 channel only [message #13119] Sun, 22 October 2006 08:51 Go to next message
Shortkut77 is currently offline  Shortkut77
Hey,
Can anyone tell me how to safely fix my turntable if audio is only coming out of the left channel? I think the wiring on the turntable itself disconnected. Thanks.
Re: Technics 1200s audio from 1 channel only [message #13121 is a reply to message #13119] Sun, 22 October 2006 11:08 Go to previous messageGo to next message
Check the connection to the cartridge, and check that there is continuity to the RCA plugs. I'm sure that's it.
Re: Technics 1200s audio from 1 channel only [message #13123 is a reply to message #13121] Sun, 22 October 2006 14:18 Go to previous message
thanks for answering. turns out one of my speakers is shot. time for new ones (and better ones). appreciate the effort though
-shortkut77
Previous Topic: Dumb Turntable Question
Next Topic: Loosing quality
Current Time: Fri Oct 23 02:10:58 CDT 2026
