Home » Sponsored » Pi Speakers » 4pi with 2226J (16 ohms)? .. crossover? (4pi with 2226J (16 ohms)? .. crossover?)
4pi with 2226J (16 ohms)? .. crossover? [message #96123] Sat, 29 October 2022 08:07 Go to next message
33 is currently offline  33
Hi all.
I'm new on this planet.. and the 4pi has fascinated me for a long time.
I would like to buy the DIY kit, but unfortunately I live in Germany. Now I'm trying to collect the individual components.
In one forum it was mentioned that a 2226J (16 ohms) can also be used. Is that correct? What would the crossover look like for 16 ohms? Or is the 4pi with 2226J not recommended.
There's a cheap pair here in 16 ohms right now.
Can you help me?
Best regards from Hamburg
Michael
Re: 4pi with 2226J (16 ohms)? .. crossover? [message #96124 is a reply to message #96123] Sat, 29 October 2022 09:13 Go to previous messageGo to next message
I would not suggest using the 2226J. The crossover was designed for the 2226H and while its values could be adjusted, I've never measured a system with a 2226J to validate. So since you're still gathering parts, find a pair of 2226H drivers to use.
Re: 4pi with 2226J (16 ohms)? .. crossover? [message #96128 is a reply to message #96124] Mon, 31 October 2022 04:24 Go to previous message
Wayne .. thank you very much, that helps me a lot. I may have a few more questions, then I'll get back to you.
Best regards
Previous Topic: Pi 4 plans please
Next Topic: 4 Pi and 3 Pi subwoofer
Current Time: Wed Oct 28 08:01:54 CDT 2026
