Home » xyzzy » Tower » Clean your fan
Clean your fan [message #96050] Sat, 08 October 2022 18:53 Go to next message
After so many years I decided to clean it. Wow, better air flow.
Re: Clean your fan [message #96051 is a reply to message #96050] Sun, 09 October 2022 09:47 Go to previous messageGo to next message
LOL! What prompted you to say that? And which device had the clogged fan?
Re: Clean your fan [message #96052 is a reply to message #96051] Sun, 09 October 2022 14:00 Go to previous messageGo to next message
I have a Vornado fan that needed cleaning, full of dust. I don't have an air conditioner. Next up to clean is the ceiling fan in the living room.
https://www.coolray.com/help-guides/can-i-use-both-air-conditioner-and-ceiling-fan-together-faq
Re: Clean your fan [message #96053 is a reply to message #96052] Sun, 09 October 2022 14:28 Go to previous messageGo to next message
https://nymag.com/strategist/article/best-ceiling-fans.html
https://nymag.com/strategist/article/best-cooling-fans.html
Please note, these reviews are just their opinion.
Re: Clean your fan [message #96054 is a reply to message #96053] Sun, 09 October 2022 16:03 Go to previous messageGo to next message
I see, gotcha. Yeah, I clean all our HVAC filters quarterly.
Re: Clean your fan [message #96055 is a reply to message #96054] Sun, 09 October 2022 22:06 Go to previous messageGo to next message
Hi, yes indeed. Our fans collect dust at an alarming rate. Once a year I end up cleaning them all. The heat pump filter gets replaced every 6 months as well. It amazes me how much dust gets into a closed up house. Out H-P works better if you never open the windows. The humidity and air temp is much better regulated and energy use is minimal if the inside and outside temps are nearly the same. That is about 1/2 the year. I have also found that many of the fans with "lifetime" lubrication are stretching it a bit. Whose lifetime? A gerbil maybe. Shocked They have to be disassembled and lubed about every two years.
Re: Clean your fan [message #96625 is a reply to message #96050] Thu, 13 April 2023 14:03 Go to previous messageGo to next message
noodle is currently offline  noodle
Appreciate the reminder! It's almost time to turn on the old ceiling fan at work, and I'm sure the blades are overdue for a dusting.
Re: Clean your fan [message #99007 is a reply to message #96625] Wed, 22 October 2025 04:36 Go to previous messageGo to next message
Helen is currently offline  Helen
I missed cleaning the fan every Saturdays. We have two standing fan and one also up the ceiling, I was made to clean two standing fans every weekend. The one in the living room and the other at our room and I was doing the work diligently while my dad took over the ceiling fan.
I'm too busy all time that I can't remember the last time that I clean the fans.
Re: Clean your fan [message #99535 is a reply to message #96050] Sat, 27 June 2026 01:35 Go to previous message
Clint is currently offline  Clint
I clean the fan every 6 months. Just like you mentioned, cleaning them ensures better air quality when in use.
Previous Topic: What Would We Be Like?
Next Topic: DOS 2 history (ping: Wayne)
Current Time: Sun Sep 13 16:26:19 CDT 2026
