Home » Sponsored » Pi Speakers » 4Pi Plans & a question
4Pi Plans & a question [message #95973] Wed, 07 September 2022 06:36 Go to next message
suddenko is currently offline  suddenko
Hi Wayne, huge fan of your work. I would love a set of 4pi plans.
Also a question. Have you explored the option of lining the enclosure with sheet lead to absorb standing waves? Seems a couple of guys do this to their high end models.
Thanks.
Re: 4Pi Plans & a question [message #95975 is a reply to message #95973] Wed, 07 September 2022 08:12 Go to previous messageGo to next message
You've got mail!
I've used various insulation materials and I've used constrained-layer panels, with PVC as the damping layer.
I haven't found any damping material that works as well as fiberglass-based R11. And while constrained layer panels definitely damp panel resonance, it didn't give any measurable improvement on my speakers. The bracing that is used is sufficient.
Re: 4Pi Plans & a question [message #95976 is a reply to message #95975] Wed, 07 September 2022 08:23 Go to previous messageGo to next message
Thank you for the plans.
Lead has amazing energy absorption properties, so I will take before and after measurements to see what it does in a larger enclosure.
Thanks again.
Re: 4Pi Plans & a question [message #96259 is a reply to message #95976] Tue, 03 January 2023 12:31 Go to previous messageGo to next message
33 is currently offline  33
Hi Wayne.
We had already emailed briefly in October.
After studying your theories very interestingly, I would like to build the 4pi.
Would you please also provide me with the blueprint for the cabinet and crossover.
Best regards.
Re: 4Pi Plans & a question [message #96260 is a reply to message #96259] Tue, 03 January 2023 13:45 Go to previous message
You've got mail!
Previous Topic: 4Pi... B&C DE250-8 or B&C DE250TN?
Next Topic: Plans for 7 Pi and 4 PI Please
Current Time: Sat Oct 17 06:11:48 CDT 2026
