Home » Audio » Source » Sony Turntable Loud Hum
Sony Turntable Loud Hum [message #13103] Wed, 04 October 2006 17:55 Go to next message
Shane M. is currently offline  Shane M.
I recently purcheced a Sony PS T15 turntabe off ebay and when i hooked it up it has a very loud hum. It sounds like a dead short, not a 60 cycle buzz. There is no ground wire so i tried connecting one from the chassis to my stereo but it didn't help. Any thoughts?
Re: Sony Turntable Loud Hum [message #13104 is a reply to message #13103] Sun, 08 October 2006 11:23 Go to previous messageGo to next message
Are both channels of the cartridge connected? In other words, can you hear sound from both channels through the hum? If not, that may be the culprit. An open line can be pretty noisy, with long wires having no termination.
Re: Sony Turntable Loud Hum [message #13105 is a reply to message #13104] Sun, 08 October 2006 17:06 Go to previous messageGo to next message
Thanks for the reply. Hum is from both channels however, the hum stops when i remove the holder/cartrige from the end of the arm. So i swapped out the cartrige with an older one and the hum is back, so i ruled out a bad cart unless both are bad. I am going to try to replace both RCA cables to see if thats it. There is no grnd wire, is this normal? Thanks again.
Re: Sony Turntable Loud Hum [message #13106 is a reply to message #13105] Mon, 09 October 2006 08:58 Go to previous messageGo to next message
If you don't have a ground wire, that's probably it. Connect the chassis and arm to the ground lug on your preamp.
Re: Sony Turntable Loud Hum [message #13107 is a reply to message #13106] Mon, 09 October 2006 17:27 Go to previous message
Problem completely solved. Thank you!
Previous Topic: Whatever happened to MiniDiscs?
Next Topic: Garrard 440M manuals
Current Time: Wed May 08 22:30:55 CDT 2024
