Home » Audio » Source » repalcing belt on sony ps-lx250h
repalcing belt on sony ps-lx250h [message #13056] Mon, 14 August 2006 11:41 Go to next message
jmarwil is currently offline  jmarwil
Hello,
Found the sony in the basement, but missing a belt, got a new belt, can't figure out how to put it on correctly. Any help would be much appreciated.
Thanks,
jmarwil
Re: repalcing belt on sony ps-lx250h [message #13058 is a reply to message #13056] Mon, 14 August 2006 16:13 Go to previous messageGo to next message
Does the platter have a rubber mat? If so, remove it and check underneath for a couple of access holes. If there are holes in the platter and you can see the base through it, you can access the belt and put it in place. Just rotate the platter and thread the belt into position.
Re: repalcing belt on sony ps-lx250h [message #13066 is a reply to message #13056] Sat, 19 August 2006 17:59 Go to previous message
Here are instructions (link below) for replacing turntable belts.
I have one thing to add... do not use 3-in-1 oil. It dries out and gets gummy. There are a number of good machine oils, Singer Sewing Machine Oil, Xacto Oil (from hobby shops), Breakfree CLP, Triflon, and others. All of these come in nice oiler tip containers.
Previous Topic: Turntable problem
Next Topic: Just got my SME arm back from re-wire. Hubba Hubba!
Current Time: Sat May 04 07:00:32 CDT 2024
