Home » Audio » Source » i just want something simple
i just want something simple [message #12986] Sun, 02 July 2006 16:44 Go to next message
big jon is currently offline  big jon
i just want a simple turntabe/record player so i can play my dads old vinyl, and pick up some random odds and sods, this may just be a fad so can i get away with spending under £100? were belt driven decks invented by the devil and used only by his puppets? do i really need all those strobey dj add on bits? your knowledge would be greatfully recieved
cheers all big jon
Re: i just want something simple [message #12990 is a reply to message #12986] Wed, 05 July 2006 10:15 Go to previous messageGo to next message
I suggest buying a Technics table. You can find good used ones cheap and they work very well.
Re: i just want something simple [message #12993 is a reply to message #12990] Wed, 05 July 2006 13:13 Go to previous messageGo to next message
the 1200 or 1210, something like that?
Re: i just want something simple [message #12994 is a reply to message #12993] Wed, 05 July 2006 15:03 Go to previous message
Yes, I think you would probably be very happy with an SL-1200.
Previous Topic: Dual CS 503-1 running fast
Next Topic: Speaker Processor
Current Time: Tue Nov 24 17:30:54 CST 2026
