Re: Can you appreciate great sound? [message #94144 is a reply to message #94142] |
Wed, 04 August 2021 00:15 |
positron
Messages: 112 Registered: May 2020
Viscount |
smartt wrote on Tue, 03 August 2021 02:30positron,
Your forum was a big loss, not to be able to read it. You are retired but please tell us about your V interconnect cable which is the only item you still make. Also tell us about your Schiit Audio upgraded Modi 2 mods. Do the mods also apply to the new Modi 3 plus? Since you retired SAS Audio Labs website is gone. I used the Wayback Machine to see the website. Although not for sale you had an idea for a new tube preamp. How is that project going? positron was and will always be a serious no compromise audiophile, a big bang for the buck product. Too bad he is retired.
Very briefly, the "V" ic is non-shielded, 39pf/meter, and uses minimum 6n pure copper wire (99.9999%). Used from pre to low gain amp.
The Modi 2 has upgraded power supply filter and output capacitors. When tested matched Monarchy 24 tube DAC, bettered the standard Border Patrol, Denafrips Aris 2 DACs. Just slightly less spacial width than the $4k Lampizator dac. I have never investigated the Modi 3, so cannot comment.
In general, everything is important whether designing/upgrading a source, ic, pre, amp, speakers. Even speaker wire inductance and total gauge is critical to performance, especially in cone type speakers.
I hope I have not broken any rules. Please delete if I have.
pos
Re: Please delete this post. [message #94176 is a reply to message #94166] |
Mon, 09 August 2021 11:38 |
positron
Viscount |
gofar99 wrote on Sun, 08 August 2021 20:59Hi, As Moderator, I don't see anything that would require that as the questions and answers are generally in the realm of diy and of some value to diy prone individuals. Wayne naturally could over rule that but it is my opinion.
Thanks Go. I felt Smartt was ok, but being rather new, I just wanted to make sure I did not over reply and be out of bounds.
Cheers
pos
