Home » Audio » Source » Denon DP-51F - Can't keep tonearm on platter
Denon DP-51F - Can't keep tonearm on platter [message #12941] Mon, 19 June 2006 05:02 Go to next message
Andrew Kanter is currently offline  Andrew Kanter
Can anyone help? I recently acquired a Denon DP-51F which is in excellent condition, but the tonearm glides across the platter. I've adjusted just about every knob that I can think of per the instructions and the service manual to no effect. Any ideas? Perhaps something is loose inside?
Re: Denon DP-51F - Can't keep tonearm on platter [message #12942 is a reply to message #12941] Mon, 19 June 2006 08:18 Go to previous messageGo to next message
Is the needle in good shape?
Re: Denon DP-51F - Can't keep tonearm on platter [message #13027 is a reply to message #12942] Sat, 29 July 2006 11:33 Go to previous message
It looks OK, but I'll be honest it's been so darn long since I looked closely that I can't be 100% sure. I could use recommendations on a replacement if one is needed. The cartridge is a DL-60.
Previous Topic: very low volume comes from the turntable
Next Topic: Goldring 1042 troubles
Current Time: Sat Oct 17 17:19:56 CDT 2026
