Home » Sponsored » Pi Speakers » 4 Pi Build in San Luis Obispo - Flush Mounting and Bracing
Re: 4 Pi Build in San Luis Obispo - Settings for Flanking Subs [message #94068 is a reply to message #94063] Tue, 20 July 2021 10:52 Go to previous messageGo to next message
It never hurts to use a high-pass filter for vented subs set at or just below the Helmholtz frequency. So if your sub cabinets are tuned to 20Hz, set a fourth-order high-pass at 15-20Hz.
Re: 4 Pi Build in San Luis Obispo - Progress [message #95582 is a reply to message #93009] Tue, 03 May 2022 12:08 Go to previous messageGo to next message
Finally starting to make some progress...... I was hoping to post as I go but I tend to work in fits and spurts when doing these kinds of projects and although I found time to work on the speakers I fell behind on my posts and updates.
/forum/index.php?t=getfile&id=3041&private=0
In order to recess the wave guides, I ended up using the same template strategy that "Roger S" used. Thanks "Roger S!" At first I tried to use my jig to cut the shape of the wave guide directly into the baffle but really struggled to get the corners right. The jig was great for cutting the general shape of the wave guide but didn't allow me to effectively address the rounded corners. So, I ended up making the template per Roger S using my jig and router and then routed the corners by hand. It took me a several tries to get it right but after a few attempts I finally got one that I was happy with. From there I used the template to cut the baffle. Worked like a charm.
/forum/index.php?t=getfile&id=3042&private=0
/forum/index.php?t=getfile&id=3046&private=0
For the woofers, I beefed up the back side of the baffle with an additional piece of wood per Wayne's recommendation in order to give them a little more "meat" to attach to. Using my jasper circle jig I cut a round disc approximately 16.25" in diameter using some ¾" cabinet grade plywood that I had lying around and glued it to the back of the baffle. I then cut the recess and hole for the woofer.
/forum/index.php?t=getfile&id=3047&private=0
/forum/index.php?t=getfile&id=3052&private=0
/forum/index.php?t=getfile&id=3051&private=0
From there I attached the baffles and vents using clamps and kettle bells.
/forum/index.php?t=getfile&id=3053&private=0
/forum/index.php?t=getfile&id=3054&private=0
For the most part I am pleased with my results thus far however I would like to point out a few issues.
#1 - Even though I had the local lumber yard cut my sheet of MDF to spec, after gluing up the box and then attaching the baffle my speaker was not perfectly square with some parts slightly hanging out over other parts. I ended up using a trim router to clean things up.
#2 - I pre-cut the hole for my vent with the intention of using a trim router to clean things up and make the opening flush and square however I got little too aggressive with the jig saw and over cut the opening in a few spots and then allowed the trim router to get away from me a few times so I now have to go back and fix the problem areas with some kind of wood filler. You can see it in the photo below and in some of the other photos in this post.
/forum/index.php?t=getfile&id=3055&private=0
Re: 4 Pi Build in San Luis Obispo - Questions for Wayne [message #95583 is a reply to message #95582] Tue, 03 May 2022 14:43 Go to previous messageGo to next message
Some questions for Wayne.
1) Ok to use foam or wax strips for gaskets? I have a bunch from other projects.
2) Waveguide is recessed. Does it require "more meat" (backing) like the woofer)?
3) Can I install a larger piece for bracing?
- I was thinking of installing a more substantial piece of bracing that would touch all 4 interior walls, add more support, and give me something to attach the insulation to.
4) I have added some backing behind the woofer. I may add backing behind the waveguide. I would also like to potentially add the bracing that I described above. At what point should I be concerned about having a material impact on the internal volume.
5) I did see your article about how to properly install T-Nuts however I am wondering if it is ok to simply use larger wood screws in place of t-nuts especially because I used plywood as the backing for my woofers?
Re: 4 Pi Build in San Luis Obispo [message #95584 is a reply to message #95583] Tue, 03 May 2022 15:15 Go to previous messageGo to next message
Your build is lookin' great!
I like the ring you've used to add "meat" behind the woofer for mounting screws. We do the exact same thing. It adds thickness where it's needed and eliminates the need for a double baffle. These speakers are heavy enough.
We do the same thing around the waveguide, which I think answers your question about that.
You could use wood screws to mount the drivers, sure. But I wouldn't. It isn't much more trouble to use T-Nuts and they provide much more clamping force without stripping. Not that you need much clamping force - 10 foot/pounds per screw is plenty - but still, the metal threads are much stronger and long-lasting.
You can add bracing if you want, but it's really only needed between the baffle and back. The rest of the panels are small enough to shift panel resonance way out of the passband. We tie the sides together at the same place - between woofer and tweeter - which is overkill but serves to provide a "perch" for the insulation that spans the cabinet interior. That's what is really important, to span the cross-section with insulation separating the midwoofer and the port. It prevents midrange from entering the port, but bass passes right through. That's its function.
As for gasket material, you could probably use your wax strips. I don't know - never used them - but the gaskets in vented loudspeakers aren't stressed so most anything that makes a decent gasket will work in this application. Almost any flat non-corrugated cardboard material is fine for a gasket. I like 40 mil PVC material, commonly used for making shower pans.
Re: 4 Pi Build in San Luis Obispo - Progress [message #97162 is a reply to message #95582] Sat, 04 November 2023 16:39 Go to previous messageGo to next message
frederf69 is currently offline  frederf69
Hello,
how did you get all this from the plans; which don't feature the recess or the hoop to support woofer. + will there be enough room for proper bracing?
Re: 4 Pi Build in San Luis Obispo - Progress [message #97165 is a reply to message #97162] Sun, 05 November 2023 09:38 Go to previous message
The cabinet is pretty simple - it's a rectangular box - so cabinetmakers don't need anything more to be able to cut and build from these plans. They're not like the 12Pi hornsubs, which really is a complicated build, and needs more detail in the drawing. But you're right that the simple plans do leave some stuff out. Most of my plans don't even show the amplifier connection panel - largely because some use Cardas binding posts but others use a different kind of panel - so but I usually just tell people to center them on the back panel, three inches up.
Same thing with the cross-brace. I just tell people to place a cross-brace between the woofer and tweeter. I suggest a pair of sticks make from the panel material, one spanning front to back and the other spanning side to side. Most people do that, but some make a panel brace. Either method works just fine.
The stuff that's important acoustically is shown in the plans though. The crossover schematic, the cabinet dimensions and the placement of the drivers, the port and the fiberglass insulation damping material. Those are important because they determine things like internal standing waves and the shape of the forward lobe and positions of the vertical nulls.
Stylistic details are left to the cabinet builder. Some make a plain box with drivers mounted on the surface of the baffle. Others cut a groove in the front with a baffle with a router so they can recess the drivers and mount them flush. When doing so, the baffle becomes thin so more support is needed. Most cut a round or square panel, glue it to the back of the baffle and cut through it. That effectively doubles the baffle thickness in the area it is needed. Some people paint their cabinets, others veneer them. Some people make grilles, and others don't.
To tell the truth, I've seen some really nice cabinetry displayed here. There are some really talented cabinet makers that have posted pics of their work here. I asked to borrow one of 'em, and hade a cabinet built just like theirs. It's now offered as an option on the three Pi model.
Previous Topic: 3Pi plans and questions
Next Topic: 3Pi Plans
Current Time: Thu Mar 28 16:44:15 CDT 2024
