Home » Audio » Speaker » Best brand for wireless speaker
Best brand for wireless speaker [message #92943] Wed, 13 January 2021 18:19 Go to next message
Mica is currently offline  Mica
We just built a new garage, 24'x36', one level with a gambrel roof (tin). I'm looking for a wireless speaker that will work in a building this size and have great sound quality. Tips on the brand to look at?
Re: Best brand for wireless speaker [message #92990 is a reply to message #92943] Fri, 22 January 2021 08:15 Go to previous messageGo to next message
Do you plan to incorporate the speaker into the rest of your home or is that functionality not important? Do you rely on a smart speaker/central hub?
Re: Best brand for wireless speaker [message #97040 is a reply to message #92943] Tue, 03 October 2023 07:34 Go to previous messageGo to next message
pietro111 is currently offline  pietro111
Depends on your budget. If you want the best you can look at KEF LS50 Wireless.
Re: Best brand for wireless speaker [message #97195 is a reply to message #92943] Thu, 16 November 2023 18:50 Go to previous messageGo to next message
My answer somewhat depends on whether you're tied to a particular smart home platform. I'd hate to start recommending Alexa compatible speakers if you're tied to Apple HomeKit.
Re: Best brand for wireless speaker [message #98924 is a reply to message #97195] Tue, 07 October 2025 12:25 Go to previous messageGo to next message
Becky is currently offline  Becky
Alexa and KEF brand are good but it can only be depended on your budget or what you like among the two. There are still other brands that you can get that are good at the stores.
Re: Best brand for wireless speaker [message #98964 is a reply to message #92943] Wed, 15 October 2025 00:55 Go to previous message
George is currently offline  George
I bought the Sonos Era 300 wireless speaker from Amazon for less than around £370. The speaker has good voice control and clarity and has served its purpose for a period of time now. One good part about the speaker is that it looks solid and hasn't had any issues since I got it.
Previous Topic: Cabinet Damping & Constrained Layer Damping (CLD)
Next Topic: T/S for Car Speakers
Current Time: Fri Nov 06 08:33:27 CST 2026
