Home » Sponsored » OddWatt Audio » Site is Down
Site is Down [message #92906] Sun, 03 January 2021 20:39 Go to next message
Hi Everyone. The Oddwatt site is down. It seems our now deceased web master used Flash and guess what .....it doesn't work now. Until we get it fixed you all can PM me at support@oddwattaudio.com That part works fine. Welcome to 2021. As a follow on last year was problematic for Oddwatt. Several of our key suppliers are shut down and at least one is gone for good. We will be back though. Our new all tube phono preamp is in a holding pattern for ...you guessed it supplier issues. I have one of the final generation pre-production ones here and use it all the time. Lovely sound. Quiet and musical. It sings with any cartridge I use. My favorite combo is with a Grado Sonata II, but a Goldring 1042 and Hana EL (with SUTs) are not far behind. My hand built initial prototype is about 95% as good and sings with a Dynavector Karat23-MR-RS with Softone SUTS.
Re: Site is Down [message #92909 is a reply to message #92906] Mon, 04 January 2021 13:22 Go to previous message
Dang, dude, I hate that kind of stuff. I maintain a few websites and so I feel your pain. Every so often, a major subsystem has to be upgraded and sometimes it's easy but sometimes it's not. Hoping you can update or renovate relatively easily.
Let me know if there's anything I can do to help.
Previous Topic: The EL34 vs 6L6 debate
Next Topic: Phono Preamp Beta Testers
Current Time: Sat Oct 31 10:07:38 CDT 2026
